| Message |
I had some suspension work done and the mech forgot to put the rubber sleeves back on the front right spring. Have had squeaking on accel/decel/braking/bumps ever since. I'm guessing that's my problem. If you've done suspension work, check that. Basically, there are a bunch of different things that could cause the sounds you are describing. Bushings, tie rods, loose bolts, springs, shocks, brakes, bearings, etc...
 VISIT thumper300zx.com for PICS and TECH PAGES |
